Inleiding
The fan on a computer is important for cooling the parts that generate a lot of heat. If fan is not running properly, there is a risk of other parts overheating and causing damage to critical components. Most computers have thermal throttling; this means speeds will decrease when it starts to overheat to prevent from damage.
Wat je nodig hebt
Push the left switch (labeled 1) to the left to show red underneath. This will unlock battery.
Push the right switch (labeled 2) to the right. This will eject battery.
Remove the three 6mm Phillips #0 screws holding the back access panel on.
6 andere personen hebben deze handleiding voltooid.
