Inleiding
This replacement is moderately difficult and should only take fifteen to twenty minuets. You will need a JIS #0 screwdriver, tweezers, and a plastic opening tool. Before you start on the speakers make sure you take out the battery.
Wat je nodig hebt
At the top of the laptop you will see two switches, like in image one and two.
Pull the switches outwards with your thumb, towards the unlocked lock.
Wedge the plastic opening tool in-between the keyboard and the base of the laptop.
Continue using the plastic opening tool to pry around the edge until the keyboard is completely freed form the frame.
The keyboard should only be connected by a ribbon on the underside of the keyboard.
Gereedschap gebruikt in deze stap:Tweezers$4.99
In order to remove the speakers you must first pull back the blue circuitry that covers the speakers.
Then, remove the left speaker by pulling it up and off the prongs holding it. Repeat this step for the right side
Next, use the tweezers to pull the connector out away from the screen.
Één andere persoon heeft deze handleiding voltooid.
