Ga door naar hoofdinhoud
Lenovo Flex 3-1120 Hard Drive Replacement
Wat je nodig hebt
  1. Lenovo Flex 3-1120 Hard Drive Replacement, Bottom Panel: stap 1, afbeelding 1 van 1
    • Lay the computer down with the bottom panel facing up.
  2. Lenovo Flex 3-1120 Hard Drive Replacement: stap 2, afbeelding 1 van 2 Lenovo Flex 3-1120 Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
    • Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
  3. Lenovo Flex 3-1120 Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Wedge the plastic opening tool into the small space under the back panel.
    • Use the plastic opening tool as a lever to separate the bottom panel from the computer.
    • Slide the tool along the edges of the computer until the bottom panel is completely separated.
    • You may start prying the bottom panel on any edge.
  4. Lenovo Flex 3-1120 Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Lift the bottom panel off of the computer.
  5. Lenovo Flex 3-1120 Hard Drive Replacement, Hard Drive: stap 5, afbeelding 1 van 1
    • Locate the hard drive in the bottom left of your computer.
  6. Lenovo Flex 3-1120 Hard Drive Replacement: stap 6, afbeelding 1 van 2 Lenovo Flex 3-1120 Hard Drive Replacement: stap 6, afbeelding 2 van 2
    • Locate the three 3.5mm Phillips screws on the corners of the hard drive.
    • Remove the three screws with a size 0 Phillips screwdriver.
  7. Lenovo Flex 3-1120 Hard Drive Replacement: stap 7, afbeelding 1 van 1
    • Follow the wire out from the right side of the hard drive to locate where the hard drive connects to the motherboard.
  8. Lenovo Flex 3-1120 Hard Drive Replacement: stap 8, afbeelding 1 van 1
    • Lift off the strip of tape securing the wire down to the computer.
  9. Lenovo Flex 3-1120 Hard Drive Replacement: stap 9, afbeelding 1 van 1
    • Pull the connector out of its port on the motherboard.
  10. Lenovo Flex 3-1120 Hard Drive Replacement: stap 10, afbeelding 1 van 1
    • Lift the hard drive out from the computer.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Geoff Bentz
934 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 7-1, Catania Spring 2016 Lid van UMass Dartmouth, Team 7-1, Catania Spring 2016
UMASSD-CATANIA-S16S7G1
4 Leden
7 handleidingen geschreven
4 opmerkingen
How do you reload operating system.... for example windows 10?
supermac200 - Antwoord
How do I get Windows 10 working again after replacing hard drive on Lenovo Flex 3?
arcinko - Antwoord
Demo models of this do not have any SATA connector.
Elilla Shadowheart - Antwoord
That sata connector is the worst thing ever
dilleremail - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 47
Altijd: 10,826
