Inleiding
Use this guide to replace a full or faulty hard drive in your Lenovo Flex 2-14 laptop.
If your Lenovo Flex 2-14 laptop (model 20404) has slowed down and is constantly freezing, you may need to replace the hard drive, especially if you have already tried other methods to fix these issues.
The hard drive stores and retrieves data in your computer. Make sure you back up your hard drive before replacing it in order to not lose any data. You may also want to upgrade your hard drive if you are running low on storage, as that can cause your laptop to slow down.
Before beginning, make sure to power off your laptop completely and disconnect from any external power source.
Wat je nodig hebt
Flip the laptop over so the bottom is facing upwards.
Remove all nine 6mm Phillips #0 screws located along the edges and in the centre of the back panel.
