Ga door naar hoofdinhoud
Lenovo Essential G560 RAM Replacement
Wat je nodig hebt
  1. Lenovo Essential G560 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Lenovo Essential G560 RAM Replacement: stap 2, afbeelding 1 van 2 Lenovo Essential G560 RAM Replacement: stap 2, afbeelding 2 van 2
    • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo Essential G560 RAM Replacement: stap 3, afbeelding 1 van 1
    • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
  4. Lenovo Essential G560 RAM Replacement, Back Panel: stap 4, afbeelding 1 van 1
    • Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
  5. Lenovo Essential G560 RAM Replacement: stap 5, afbeelding 1 van 2 Lenovo Essential G560 RAM Replacement: stap 5, afbeelding 2 van 2
    • Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
  6. Lenovo Essential G560 RAM Replacement: stap 6, afbeelding 1 van 1
    • The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
  7. Lenovo Essential G560 RAM Replacement, RAM: stap 7, afbeelding 1 van 2 Lenovo Essential G560 RAM Replacement, RAM: stap 7, afbeelding 2 van 2
    • Locate the RAM Sticks in the computer. They should be in the corner of the laptop.
  8. Lenovo Essential G560 RAM Replacement: stap 8, afbeelding 1 van 2 Lenovo Essential G560 RAM Replacement: stap 8, afbeelding 2 van 2
    • Using a spudger, push one of the metal rods on either side of the RAM stick away from it until you hear a light clicking noise. Repeat this procedure on the other metal rod on the opposite side of the RAM stick.
    • If you push both metal rods away from the RAM stick as directed, the RAM stick will pop up at an angle.
  9. Lenovo Essential G560 RAM Replacement: stap 9, afbeelding 1 van 1
    • Gently pull out the stick of RAM.
    • If you wish to remove the second stick of RAM, do so by following steps two and three again.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Dennis Wong
609 Reputatie
5 handleidingen geschreven
Cal Poly, Team 18-40, Regan Winter 2013 Lid van Cal Poly, Team 18-40, Regan Winter 2013
CPSU-REGAN-W13S18G40
5 Leden
7 handleidingen geschreven
Één opmerking
maine apne lenovo g560 laptop me crucial 4gb ram add kiya lekin mera system format nahi ho raha h. mujhe kya karna chahiye mujhe email kare. vikasmaddeshiya056@gmail.com
vikkivikas056 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 11,156
