Ga door naar hoofdinhoud
Lenovo Essential G560 Individual Keyboard Keys Replacement
  1. Lenovo Essential G560 Individual Keyboard Keys Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Lenovo Essential G560 Individual Keyboard Keys Replacement: stap 2, afbeelding 1 van 2 Lenovo Essential G560 Individual Keyboard Keys Replacement: stap 2, afbeelding 2 van 2
    • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo Essential G560 Individual Keyboard Keys Replacement: stap 3, afbeelding 1 van 1
    • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
  4. Lenovo Essential G560 Individual Keyboard Keys Replacement, Individual Keyboard Keys: stap 4, afbeelding 1 van 1
    • Place your pointer finger under the key you want to remove. For extra leverage, use the thumb and rotate the key in the manner shown.
  5. Lenovo Essential G560 Individual Keyboard Keys Replacement: stap 5, afbeelding 1 van 1
    • The key will come off with a popping sound.
    • You will now be able to see the mechanism below the key. Clean this area using compressed air, then replace the key.
Conclusie
To reassemble your keyboard, push the key back into the original spot.
8 andere personen hebben deze handleiding voltooid.
Lawrence Downs
383 Reputatie
2 handleidingen geschreven
Cal Poly, Team 18-40, Regan Winter 2013 Lid van Cal Poly, Team 18-40, Regan Winter 2013
CPSU-REGAN-W13S18G40
5 Leden
7 handleidingen geschreven
2 opmerkingen
I used your guide to install the key, thank you. I bought my lenovo keys from this link below
http://www.replacementlaptopkeys.com/len...
keep up the good work.
Resteasy - Antwoord
Hello , you can buy single keys on this site:
http://www.laptopkey-europe.eu/
John Pohl - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 23
Altijd: 8,566
