Inleiding
The hard drive is likely to malfunction when dropped or put under a lot of stress. If the computer won't boot and is having hard disk/hard drive reading errors, follow this guide to replace it.
Gereedschap
Onderdelen
Turn off the computer.
Disconnect the charging cable from the computer.
Flip the computer upside down.
Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
Remove the two 5.33 mm Phillips #1 screws holding the hard drive in place.
8 andere personen hebben deze handleiding voltooid.
2 Opmerkingen
In step 1, failure to unplug the cable does not result in electric shock. The power supply voltage is too low for such shock to happen to a human, but it can cause electrical damage to the motherboard. It is always a safe procedure to work on any machine unpowered (both power supply and battery disconnected and/or removed).
In step 9, be sure to remember the direction that the original drive was pointing when removing. The new drive must point the same direction.
