Ga door naar hoofdinhoud
Lenovo Essential G560 Battery Replacement
  1. Lenovo Essential G560 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Lenovo Essential G560 Battery Replacement: stap 2, afbeelding 1 van 2 Lenovo Essential G560 Battery Replacement: stap 2, afbeelding 2 van 2
    • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo Essential G560 Battery Replacement: stap 3, afbeelding 1 van 1
    • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
Conclusie
To reassemble your battery, line up the battery and slide it in until the second lock (left hand switch) clicks. Then lock the 1st switch.
14 andere personen hebben deze handleiding voltooid.
Dennis Wong
609 Reputatie
5 handleidingen geschreven
Cal Poly, Team 18-40, Regan Winter 2013 Lid van Cal Poly, Team 18-40, Regan Winter 2013
CPSU-REGAN-W13S18G40
5 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 5,482
