Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
You can use this guide to remove the heat sink in for cleaning, replacement or to gain access to the CPU.
Onderdelen
Geen onderdelen opgegeven.
  1. Unscrew the two 5.1 mm screws that secure the bottom cover.
    • Unscrew the two 5.1 mm screws that secure the bottom cover.
    • Note that the screws will not come all the way out of the sockets.
  2. Lift from the notch until the back panel comes up.
    • Lift from the notch until the back panel comes up.
  3. Disconnect the fan from the motherboard by pulling the plug shown in the picture.
    • Disconnect the fan from the motherboard by pulling the plug shown in the picture.
  4. Unscrew the three 4.6mm screws shown in the picture.
    • Unscrew the three 4.6mm screws shown in the picture.
  5. Gently lift the fan straight up until it is lifted out of the case.
    • Gently lift the fan straight up until it is lifted out of the case.
  6. Unscrew the four 7.3 mm screws shown in the picture.
    • Unscrew the four 7.3 mm screws shown in the picture.
    • Note that springs are attached to the screws. Do not remove the springs.
  7. Pull the heat sink assembly out of the laptop. Pull the heat sink assembly out of the laptop.
    • Pull the heat sink assembly out of the laptop.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Één commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 53
