Ga door naar hoofdinhoud
Lenovo Chromebook 300e Daughter Board Replacement
Wat je nodig hebt
    • Check out other guides for removal of the keyboard for Lenovo N23/N21 Chromebooks.
    • Remove the screws from the bottom of the Chromebook.
    • On a clean surface, fold the Chromebook screen over to the back to remove the keyboard.
    • Using a Jimmy remove the keyboard starting at the top of the keyboard.
    • When the entire keyboard has been popped up lift the keyboard from the end opposite the trackpad and carefully disconnect the trackpad and keyboard ribbon cables.
    • Flip over the keyboard so that the keys side is down and place it to the side of your workspace.
    • Check that the thermal pad is still stuck to either the keyboard or the motherboard.
    • Power off the computer by holding down the power button for a few seconds.
    • Disconnect the battery
    • Remove the ribbon cable connecting the Daughter and Motherboard from the motherboard side first.
    • Remove the ribbon cable from the daughter board.
    • Remove the four screws to release the motherboard.
    • Disconnect the speaker wire from the daughterboard.
    • Remove the daughterboard from the Chromebook.
    • Place the new daughterboard in the chromebook.
    • Plug in the speakers to the daughterboard.
    • Screw the daughterboard into place.
    • Connect the ribbon cable, first to the daughterboard and then to the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nathan King
353 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 727
