Inleiding
The RAM card should be replaced if the computer won't boot, or if the computer is not running at an optimal speed. Replacing the RAM card for this laptop is a fairly easy process..
Wat je nodig hebt
Turn off the computer.
Disconnect the charger from the computer.
Flip the computer upside down.
Using the Phillips #00 Screwdriver, Loosen the five 5.4 mm screws around the back panel from the laptop.
Using a plastic opening tool, pry the RAM upwards until the card pops out of the brackets.
Pull the RAM out from the slot.
Één andere persoon heeft deze handleiding voltooid.
