Ga door naar hoofdinhoud
Lenovo B575-1450 CD-ROM Drive Replacement
Wat je nodig hebt
  1. Lenovo B575-1450 CD-ROM Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off the computer.
    • Disconnect the charger from the computer.
    • Flip the computer upside down.
  2. Lenovo B575-1450 CD-ROM Drive Replacement: stap 2, afbeelding 1 van 2 Lenovo B575-1450 CD-ROM Drive Replacement: stap 2, afbeelding 2 van 2
    • Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo B575-1450 CD-ROM Drive Replacement: stap 3, afbeelding 1 van 3 Lenovo B575-1450 CD-ROM Drive Replacement: stap 3, afbeelding 2 van 3 Lenovo B575-1450 CD-ROM Drive Replacement: stap 3, afbeelding 3 van 3
    • While holding the battery, use your other hand to push the left clip to the left and pull the battery out.
  4. Lenovo B575-1450 CD-ROM Drive Replacement, Back Panel: stap 4, afbeelding 1 van 2 Lenovo B575-1450 CD-ROM Drive Replacement, Back Panel: stap 4, afbeelding 2 van 2
    • The screws are captive to the back panel so they are not to be removed.
    • Using the Phillips #00 Screwdriver, Loosen the five 5.4 mm screws around the back panel from the laptop.
  5. Lenovo B575-1450 CD-ROM Drive Replacement: stap 5, afbeelding 1 van 1
    • Using a plastic opening tool, pry the back panel from the laptop.
  6. Lenovo B575-1450 CD-ROM Drive Replacement: stap 6, afbeelding 1 van 1
    • Pull the panel outward from the rest of the laptop. The inside of the laptop will be exposed. From here you can access the CD-ROM drive, hard drive, and Keyboard.
  7. Lenovo B575-1450 CD-ROM Drive Replacement, CD-ROM Drive: stap 7, afbeelding 1 van 2 Lenovo B575-1450 CD-ROM Drive Replacement, CD-ROM Drive: stap 7, afbeelding 2 van 2
    • Using the Phillips #00 Screwdriver, remove the 3.4 mm screw from the CD-ROM bracket.
    • This unlocks the CD-ROM drive from the computer
  8. Lenovo B575-1450 CD-ROM Drive Replacement: stap 8, afbeelding 1 van 2 Lenovo B575-1450 CD-ROM Drive Replacement: stap 8, afbeelding 2 van 2
    • Pry CD-ROM drive from laptop using a plastic opening tool.
    • Pull the CD-ROM drive the rest of the way out.
Conclusie
Één opmerking
Can u please show me how to assemble or fix dvd drive lock mechanism for lenovo e49.
nukuvsh4 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 14
Altijd: 496
