Ga door naar hoofdinhoud
Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement
Wat je nodig hebt
Video overzicht
  1. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Switch off the laptop, disconnect the AC adapter, and remove the battery.
  2. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory / HDD cover: stap 2, afbeelding 1 van 2 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory / HDD cover: stap 2, afbeelding 2 van 2
    • Remove the screws securing the Memory / HDD cover.
    • Slide the cover down and remove it.
  3. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory Modules: stap 3, afbeelding 1 van 2 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory Modules: stap 3, afbeelding 2 van 2
    • To pop up the memory module you’ll have to spread latches on both sides of the slot.
    • MEMORY
    • Speed 1600 MHz / PC3L-12800
    • Technology DDR3L SDRAM SODIMM
    • Max Supported Size 16 GB
    • Form Factor SO-DIMM 204-pin
    • Slots Qty 2
    • Empty Slots 1
  4. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): stap 4, afbeelding 1 van 3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): stap 4, afbeelding 2 van 3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): stap 4, afbeelding 3 van 3
    • Remove two screws securing the hard drive mounting bracked.
    • Slide the HDD to the left to disconnect it from the motherboard and remove it from the device.
    • Remove two screws on each side of the HDD to remove the mounting bracket.
    • Now you have to transfer the mounting bracket to the new HDD or SSD.
  5. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Wireless / Bluetooth Card: stap 5, afbeelding 1 van 2 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Wireless / Bluetooth Card: stap 5, afbeelding 2 van 2
    • Remove the screw and disconnect the two coaxial antenna cables from the WiFi card.
    • Pop it up and remove it from the slot.
    • Wireless N M.2, or Next Generation Form Factor (NGFF) Card.
  6. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: stap 6, afbeelding 1 van 3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: stap 6, afbeelding 2 van 3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: stap 6, afbeelding 3 van 3
    • Complementary Metal-Oxide-Semiconductor (CMOS) aka Real-Time Clock (RTC)
    • CR2032
  7. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement: stap 7, afbeelding 1 van 1
    • That's all.
Conclusie
3 andere personen hebben deze handleiding voltooid.
ZFix
191.470 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
321 Leden
1.483 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 77
Altijd: 7,311
