Ga door naar hoofdinhoud
Lenovo A8-50 Motherboard and Speaker Replacement
Wat je nodig hebt
  1. Lenovo A8-50 Motherboard and Speaker Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the back cover by prying it open with the metal spudger tool.
  2. Lenovo A8-50 Motherboard and Speaker Replacement: stap 2, afbeelding 1 van 1
    • Remove the two screws with a PH000 head screwdriver.
    • Keep all your screws in one place.
  3. Lenovo A8-50 Motherboard and Speaker Replacement: stap 3, afbeelding 1 van 1
    • Remove the metal piece.
    • Keep this piece safe, as you will need it to reassemble the device again.
  4. Lenovo A8-50 Motherboard and Speaker Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery by lifting it up using a plastic spudger.
  5. Lenovo A8-50 Motherboard and Speaker Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the cable from the connection.
    • Be careful not to tear or bend the cable.
  6. Lenovo A8-50 Motherboard and Speaker Replacement, Motherboard and Speaker: stap 6, afbeelding 1 van 1
    • Unscrew the 5 black screws, and the 9 silver screws with a PH000 head screwdriver.
    • Set aside carefully.
  7. Lenovo A8-50 Motherboard and Speaker Replacement: stap 7, afbeelding 1 van 2 Lenovo A8-50 Motherboard and Speaker Replacement: stap 7, afbeelding 2 van 2
    • Remove the two black panels and the clear circle piece.
  8. Lenovo A8-50 Motherboard and Speaker Replacement: stap 8, afbeelding 1 van 1
    • Lift up the motherboard carefully, ensuring that you lift the speaker housing and the motherboard together
  9. Lenovo A8-50 Motherboard and Speaker Replacement: stap 9, afbeelding 1 van 1
    • Lift the bottom speaker piece up carefully
Conclusie
Jay Shah
503 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 17
Altijd: 1,280
