Inleiding
If you forgot your password, screen lock or you have a problem with the Android OS or you want to erase all information from your table, you can do this with a Factory, Hard reset.
You can do this from Android System Recovery menu or from Factory mode menu.
Wat je nodig hebt
Video overzicht
1. Switch of the tablet. If the device freezes, you can use a reset hole under the memory card reader cover.
2. Press and hod: Volume Up + Volume Down + Power buttons.
3. In the Recovery menu, use the Volume Down button to move the highlight and the Volume Up to select.
4. Choose one by one: "wipe data/factory reset", "Yes -- delete all user data" and finally "reboot system now".
1. Switch off the tablet.
2. Press and hold the Volume Up and Power On keys.
3. When you feel release only the Power button. Now your device is in Factory mode.
4. Use the Volume Up/Down keys for movement and the Power key for select.
5. Select ¶§ eMMC (Clean eMMC)
Did you do it successfully?
no, i cant do it
How can i change that language to english
I pressed reset button and selected eMMC (only thing appearing in English alphabet). Thought when LENOVO appeared on screen that was previously just dark that I had successfully rebooted. Now, however, there is a spinning circle like you get when a video is buffering. This has been on for at least 15 minutes. What now??
I have the same case, what should I do ? Can u help me? Thanks!
Please help me .tablet doent give recovery screen .it open all trial
33 andere personen hebben deze handleiding voltooid.
17 opmerkingen
let me try and see
yes it works thanks
Love you so much goodnight baby
Well thanks!! I was worried about my tab and now i can fix easily tab without paying others to fix my tab. Thank you again :))
my tablet is freezed and have no act on this way u said, i try a lot of internet advice , but still is not working , it is freezed
will it remove all photos ??
i have problem with my tab A3500
its restart alone without asking me
i try format it it but the problem still
what can i do
please help me
I m still having problems rebooting it it just opens no android sign comes
i have 1 problem, i have try all these methods and its not working, it because when i'm doing system update, it going to hard reset and i don't know what to chose, then i click "wipe cache partities" and then it going to black dead screen. i don't know why. please help me :( thank you. #sorry my bad english
Started giving a high radiolike off frequency noise, then blanked out the screen and now does not power off nor reboot. Any hints?
-KP
My tab A3500 has a problem,this pop out says "unfortunately lenovo launcher has stop" then I can not open all my apps,all the time is pop out blocks all apps,what will I do.am afraid to reformat cos I may lost all my pictures and data,please help me!!!
Thank you.
I have done the forementioned steps, but stuck on logo, will not start booting, any advice?
I have an Imac sierra osx
What's up brother and sister are Girls Good you are
when i press power key+volume up key nothing happened.. what can i do?
samasdn - Antwoord
My tab is rooted and I upgraded my lenovo tab 2
shammas.vot - Antwoord
so I hold the up and down volumes let's at the same time for 10. right?
britt - Antwoord
hold the up button on the Side and the the power button should that work?
britt - Antwoord
i did the instruction for a several times but nothings happened…the unlock pattern is still there….is there any way to fix it..
khellyanne0929 - Antwoord
