Ga door naar hoofdinhoud
Lenovo A7-40, A7-50 A3500 Factory Reset
Wat je nodig hebt
Video overzicht
  1. Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 1: stap 1, afbeelding 1 van 3 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 1: stap 1, afbeelding 2 van 3 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 1: stap 1, afbeelding 3 van 3
    • 1. Switch of the tablet. If the device freezes, you can use a reset hole under the memory card reader cover.
    • 2. Press and hod: Volume Up + Volume Down + Power buttons.
    • 3. In the Recovery menu, use the Volume Down button to move the highlight and the Volume Up to select.
    • 4. Choose one by one: "wipe data/factory reset", "Yes -- delete all user data" and finally "reboot system now".
    when i press power key+volume up key nothing happened.. what can i do?
    samasdn - Antwoord
    My tab is rooted and I upgraded my lenovo tab 2
    shammas.vot - Antwoord
    so I hold the up and down volumes let's at the same time for 10. right?
    britt - Antwoord
    hold the up button on the Side and the the power button should that work?
    britt - Antwoord
    i did the instruction for a several times but nothings happened…the unlock pattern is still there….is there any way to fix it..
    khellyanne0929 - Antwoord
  2. Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 2: stap 2, afbeelding 1 van 3 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 2: stap 2, afbeelding 2 van 3 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 2: stap 2, afbeelding 3 van 3
    • 1. Switch off the tablet.
    • 2. Press and hold the Volume Up and Power On keys.
    • 3. When you feel release only the Power button. Now your device is in Factory mode.
    • 4. Use the Volume Up/Down keys for movement and the Power key for select.
    • 5. Select ¶§ eMMC (Clean eMMC)
    • Did you do it successfully?
    no, i cant do it
    Dewie Oktasari - Antwoord
    How can i change that language to english
    Clement Learn - Antwoord
    2nd variant helped thanx a lot
    edemko - Antwoord
    I pressed reset button and selected eMMC (only thing appearing in English alphabet). Thought when LENOVO appeared on screen that was previously just dark that I had successfully rebooted. Now, however, there is a spinning circle like you get when a video is buffering. This has been on for at least 15 minutes. What now??
    D. L. Perry - Antwoord
    I have the same case, what should I do ? Can u help me? Thanks!
    Peachengg00 -
    Please help me .tablet doent give recovery screen .it open all trial
    roshan_4ever2010 - Antwoord
Conclusie
33 andere personen hebben deze handleiding voltooid.
ZFix
191.055 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.506 handleidingen geschreven
17 opmerkingen
let me try and see
usman aleeyu - Antwoord
Is it applicable to my lenovo a516?
valvinzon - Antwoord
yes it works thanks
abdullahjanajy - Antwoord
Love you so much goodnight baby
Van Prince -
Well thanks!! I was worried about my tab and now i can fix easily tab without paying others to fix my tab. Thank you again :))
Christian Lemuel Espenilla - Antwoord
my tablet is freezed and have no act on this way u said, i try a lot of internet advice , but still is not working , it is freezed
afshin Bahrami - Antwoord
will it remove all photos ??
Mahmoud Elnaggar - Antwoord
i have problem with my tab A3500
its restart alone without asking me
i try format it it but the problem still
what can i do
please help me
bandar baffan - Antwoord
I m still having problems rebooting it it just opens no android sign comes
Mohsin khan - Antwoord
After factory reset I don't habe any virtual keyboard an many alerts about google services not available.
What can I do?
fb - Antwoord
منتج رائع جدا جدا ويستحق الاقتناء
تحياتي
www.alex-translation.com/
مكتب ترجمة معتمد بالإسكندرية - الإسكندرية للترجمة المعتمدة - معتمد من السفارة الإمريكية
msmak22 - Antwoord
i have 1 problem, i have try all these methods and its not working, it because when i'm doing system update, it going to hard reset and i don't know what to chose, then i click "wipe cache partities" and then it going to black dead screen. i don't know why. please help me :( thank you. #sorry my bad english
Paulus Farrel - Antwoord
Started giving a high radiolike off frequency noise, then blanked out the screen and now does not power off nor reboot. Any hints?
-KP
Kim Pettersson - Antwoord
My tab A3500 has a problem,this pop out says "unfortunately lenovo launcher has stop" then I can not open all my apps,all the time is pop out blocks all apps,what will I do.am afraid to reformat cos I may lost all my pictures and data,please help me!!!
Thank you.
Jing Padernal - Antwoord
I have done the forementioned steps, but stuck on logo, will not start booting, any advice?
I have an Imac sierra osx
Thorstein Hansen - Antwoord
thank you♥ ♥ ♥ ♥ ♥ ♥ ♥ ♥ ♥ ♥ ♥ ♥ ♥ ♥ ♥ ♥
bad 3 - Antwoord
What's up brother and sister are Girls Good you are
Van Prince -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 40
Afgelopen 30 dagen: 123
Altijd: 106,039
