Ga door naar hoofdinhoud
Lenovo 300e Chromebook USB and Charging Ports Replacement
Wat je nodig hebt
  1. Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: stap 1, afbeelding 1 van 3 Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: stap 1, afbeelding 2 van 3 Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
  2. Lenovo 300e Chromebook USB and Charging Ports Replacement: stap 2, afbeelding 1 van 3 Lenovo 300e Chromebook USB and Charging Ports Replacement: stap 2, afbeelding 2 van 3 Lenovo 300e Chromebook USB and Charging Ports Replacement: stap 2, afbeelding 3 van 3
    • Use a spudger along the edge of the Chromebook to gently remove the back cover of the laptop.
  3. Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: stap 3, afbeelding 1 van 3 Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: stap 3, afbeelding 2 van 3 Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: stap 3, afbeelding 3 van 3
    • Remove three 5 mm screws from the USB board using a Phillips #2 screwdriver.
  4. Lenovo 300e Chromebook USB and Charging Ports Replacement: stap 4, afbeelding 1 van 3 Lenovo 300e Chromebook USB and Charging Ports Replacement: stap 4, afbeelding 2 van 3 Lenovo 300e Chromebook USB and Charging Ports Replacement: stap 4, afbeelding 3 van 3
    • Detach the white and blue ribbon cable from its cable connector on the USB board.
    • Remove the USB board from the laptop.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Do you have same instructions for Lenovo 300e Gen2, I opened and usb ports are soldered with the motherboard, I am having some troubles to replace the usb c, any recommendation?
Juan Raul Hernandez - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 41
Altijd: 1,450
