Wat je nodig hebt
Gereedschap gebruikt in deze stap:Phillips #0 Screwdriver$5.49
Remove all 9 screws on the back of the Chromebook with a Phillips #0 screwdriver
Use an opening tool such as a spudgerand carefully work your way around the laptop to remove the back cover
Remove the black tape covering the connector, then using a spudge tool, carefully unplug the battery from the motherboard
Disconnect the Trackpad Cable by lifting the Connector.
Remove the 3 screws holding in the top of the trackpad with a Phillips #0 screwdriver
