Ga door naar hoofdinhoud
Lenovo 100s Chromebook-11IBY Speaker Replacement
Wat je nodig hebt
  1. Lenovo 100s Chromebook-11IBY Speaker Replacement, Speakers: stap 1, afbeelding 1 van 1
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Speaker Replacement: stap 2, afbeelding 1 van 1
    • Use a #0 Phillips screwdriver to remove the nine 6mm screws from the larger back plate.
  3. Lenovo 100s Chromebook-11IBY Speaker Replacement: stap 3, afbeelding 1 van 2 Lenovo 100s Chromebook-11IBY Speaker Replacement: stap 3, afbeelding 2 van 2
    • Turn your laptop back over, open it, and use the plastic opening tool on the recessed notch to gently pry each side and lift the keyboard plate up.
    • Be careful not to pull keyboard plate out immediately because cables are attached.
  4. Lenovo 100s Chromebook-11IBY Speaker Replacement: stap 4, afbeelding 1 van 3 Lenovo 100s Chromebook-11IBY Speaker Replacement: stap 4, afbeelding 2 van 3 Lenovo 100s Chromebook-11IBY Speaker Replacement: stap 4, afbeelding 3 van 3
    • Locate the two sticker-like connecting wires (for the keyboard and touchpad).
    • Carefully unplug the orange circled (keyboard) wire from the keyboard plate.
    • Carefully unplug the yellow circled (touchpad) wire from the keyboard plate.
    • Then lift the keyboard plate up and place it to the side.
  5. Lenovo 100s Chromebook-11IBY Speaker Replacement: stap 5, afbeelding 1 van 1
    • Locate the cable attaching the left speaker to the motherboard and unplug it by hand.
    • Then unplug the cable attaching the right speaker by hand.
  6. Lenovo 100s Chromebook-11IBY Speaker Replacement: stap 6, afbeelding 1 van 2 Lenovo 100s Chromebook-11IBY Speaker Replacement: stap 6, afbeelding 2 van 2
    • Carefully pry the speaker up and free of the two notches holding it in place.
    • Remove the speaker.
  7. Lenovo 100s Chromebook-11IBY Speaker Replacement: stap 7, afbeelding 1 van 1
    • Repeat steps 5 & 6 in order to remove the right speaker.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Milton Perez
630 Reputatie
5 handleidingen geschreven
USF Tampa, Team S7-G2, Cagle Spring 2017 Lid van USF Tampa, Team S7-G2, Cagle Spring 2017
USFT-CAGLE-S17S7G2
1 Lid
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 508
