Ga door naar hoofdinhoud
Lenovo 100s Chromebook-11IBY Screen Replacement
Wat je nodig hebt
  1. Lenovo 100s Chromebook-11IBY Screen Replacement, Screen: stap 1, afbeelding 1 van 1
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Screen Replacement: stap 2, afbeelding 1 van 1
    • Use the plastic opening tool on the recessed notch to gently pry each side of around the screen up.
  3. Lenovo 100s Chromebook-11IBY Screen Replacement: stap 3, afbeelding 1 van 2 Lenovo 100s Chromebook-11IBY Screen Replacement: stap 3, afbeelding 2 van 2
    • Carefully pry up and underneath both the (left & right) hinges of the screen cover.
  4. Lenovo 100s Chromebook-11IBY Screen Replacement: stap 4, afbeelding 1 van 1
    • Use the opening tool on the inside of the screen plate and again on the sides to gently remove it.
  5. Lenovo 100s Chromebook-11IBY Screen Replacement: stap 5, afbeelding 1 van 2 Lenovo 100s Chromebook-11IBY Screen Replacement: stap 5, afbeelding 2 van 2
    • Use the #0 Phillips screwdriver to remove the four 6mm screws from the screen.
  6. Lenovo 100s Chromebook-11IBY Screen Replacement: stap 6, afbeelding 1 van 1
    • Gently remove the screen from the plate and place it on the keyboard.
    • Be careful not to pull screen the immediately or completely out because cables are attached.
  7. Lenovo 100s Chromebook-11IBY Screen Replacement: stap 7, afbeelding 1 van 1
    • Gently remove the adhesive tape from the back of the screen.
  8. Lenovo 100s Chromebook-11IBY Screen Replacement: stap 8, afbeelding 1 van 1
    • Unplug the screen from the laptop.
  9. Lenovo 100s Chromebook-11IBY Screen Replacement: stap 9, afbeelding 1 van 2 Lenovo 100s Chromebook-11IBY Screen Replacement: stap 9, afbeelding 2 van 2
    • The screen may now be removed completely from the laptop.
    • The back side of the screen has the screen's model number and manufacturer.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Milton Perez
630 Reputatie
5 handleidingen geschreven
USF Tampa, Team S7-G2, Cagle Spring 2017 Lid van USF Tampa, Team S7-G2, Cagle Spring 2017
USFT-CAGLE-S17S7G2
1 Lid
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 1,712
