Ga door naar hoofdinhoud
Lenovo 100e Chromebook 2nd Gen Trackpad Replacement
Wat je nodig hebt
  1. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: stap 2, afbeelding 1 van 2 Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: stap 2, afbeelding 2 van 2
    • Open the laptop and lay it flat.
    • Go along the edge of the keyboard with an opening tool until it pops loose.
    • Potential for device damage: Make sure that the keyboard does not fall away from the laptop, as it is still connected to the internal components
  3. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: stap 3, afbeelding 1 van 2 Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: stap 3, afbeelding 2 van 2
    • Lift the keyboard connectors up using an opening pick.
    • Remove the connectors from their sockets.
  4. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement, Trackpad: stap 4, afbeelding 1 van 1
    • Remove the three 2 mm Phillips #00 screws holding the trackpad in.
  5. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: stap 5, afbeelding 1 van 2 Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: stap 5, afbeelding 2 van 2
    • Push up on the side of the trackpad that faces the screen.
    • Pop the trackpad out and remove it from the laptop.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 1,117
