Ga door naar hoofdinhoud
Lenovo 100e Chromebook 2nd Gen Speakers Replacement
Wat je nodig hebt
  1. Lenovo 100e Chromebook 2nd Gen Speakers Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 100e Chromebook 2nd Gen Speakers Replacement: stap 2, afbeelding 1 van 2 Lenovo 100e Chromebook 2nd Gen Speakers Replacement: stap 2, afbeelding 2 van 2
    • Open the laptop and lay it flat.
    • Go along the edge of the keyboard with an opening tool until it pops loose.
    • Potential for device damage: Make sure that the keyboard does not fall away from the laptop, as it is still connected to the internal components
  3. Lenovo 100e Chromebook 2nd Gen Speakers Replacement: stap 3, afbeelding 1 van 2 Lenovo 100e Chromebook 2nd Gen Speakers Replacement: stap 3, afbeelding 2 van 2
    • Lift the keyboard connectors up using an opening pick.
    • Remove the connectors from their sockets.
  4. Lenovo 100e Chromebook 2nd Gen Speakers Replacement, Speakers: stap 4, afbeelding 1 van 1
    • Using an opening pick, disconnect the speakers from the headphone jack.
  5. Lenovo 100e Chromebook 2nd Gen Speakers Replacement: stap 5, afbeelding 1 van 1
    • Remove the two 2 mm Phillips #0 screws holding both of the speakers in.
  6. Lenovo 100e Chromebook 2nd Gen Speakers Replacement: stap 6, afbeelding 1 van 1
    • The speakers are now loose and can be removed from the laptop.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 554
