Ga door naar hoofdinhoud
Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement
Wat je nodig hebt
  1. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: stap 2, afbeelding 1 van 2 Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: stap 2, afbeelding 2 van 2
    • Open the laptop and lay it flat.
    • Go along the edge of the keyboard with an opening tool until it pops loose.
    • Potential for device damage: Make sure that the keyboard does not fall away from the laptop, as it is still connected to the internal components
  3. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: stap 3, afbeelding 1 van 2 Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: stap 3, afbeelding 2 van 2
    • Lift the keyboard connectors up using an opening pick.
    • Remove the connectors from their sockets.
  4. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement, Headphone Jack: stap 4, afbeelding 1 van 1
    • Remove the three 4 mm Phillips #0 screws holding the headphone jack in place.
  5. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: stap 5, afbeelding 1 van 1
    • Using a plastic opening pick, remove the connection between the aux port and the speakers.
  6. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: stap 6, afbeelding 1 van 1
    • Using the plastic opening pick, pop the retaining flap holding the ribbon cable in place.
    • Remove the headphone jack from the laptop.
Conclusie
Één opmerking
I believe our model has the headphone jack soldered on. Any other ideas?
L Hart - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 957
