Ga door naar hoofdinhoud
Lenovo 100e Chromebook 2nd Gen Camera Replacement
Wat je nodig hebt
  1. Lenovo 100e Chromebook 2nd Gen Camera Replacement, Screen Bezel: stap 1, afbeelding 1 van 1
    • Using a spudger, go along the edge of the screen and pop the connections between the cover and the back side out.
  2. Lenovo 100e Chromebook 2nd Gen Camera Replacement: stap 2, afbeelding 1 van 1
    • Insert the spudger into the gap between the hinges and pull up to detach the connections.
  3. Lenovo 100e Chromebook 2nd Gen Camera Replacement: stap 3, afbeelding 1 van 1
    • Remove the screen bezel from the laptop.
  4. Lenovo 100e Chromebook 2nd Gen Camera Replacement, Camera: stap 4, afbeelding 1 van 1
    • Using the opening pick, pry the camera from the front of the laptop.
  5. Lenovo 100e Chromebook 2nd Gen Camera Replacement: stap 5, afbeelding 1 van 1
    • Carefully pinch and pull on the connection between the camera and the motherboard.
    • The camera is now loose and can be removed.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 531
