Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Carefully unscrew the four Phillips #0 screws on the bottom of the camera.
Open the back door on the camera by pushing down on the door latch.
Apply pressure to the bottom plate and it will pop off.
From here, you can replace the bottom plate, or continue on to further steps.
Now that you've removed the bottom plate, you can pull apart the front and back covers.
Start with the front cover and, by applying pressure (perhaps a lot of pressure), snap off the front cover.
Next, the back cover.
Apply pressure to remove the back plate.
The best way to remove the back is to stick your thumbs on either side of the battery socket and separate from there.
You should now have removed the front and back plates.
Removing the flash diffuser should be simple from here.
Simply take the front cover and apply pressure to the front of the flash diffuser and it should pop right out.
Één andere persoon heeft deze handleiding voltooid.
