Ga door naar hoofdinhoud
Leica Z2X Flash Diffuser Replacement
Wat je nodig hebt
  1. Leica Z2X Flash Diffuser Replacement, Remove the Bottom Screws: stap 1, afbeelding 1 van 1
    • Carefully unscrew the four Phillips #0 screws on the bottom of the camera.
    • There is a screw located inside of the tripod hole (large circle.) Make sure the screw is removed from there too!
  2. Leica Z2X Flash Diffuser Replacement, Open the Back Door: stap 2, afbeelding 1 van 1
    • Open the back door on the camera by pushing down on the door latch.
  3. Leica Z2X Flash Diffuser Replacement, Remove the Bottom Plate: stap 3, afbeelding 1 van 1
    • Apply pressure to the bottom plate and it will pop off.
    • From here, you can replace the bottom plate, or continue on to further steps.
  4. Leica Z2X Flash Diffuser Replacement, Flash Diffuser: stap 4, afbeelding 1 van 1
    • Now that you've removed the bottom plate, you can pull apart the front and back covers.
    • Start with the front cover and, by applying pressure (perhaps a lot of pressure), snap off the front cover.
  5. Leica Z2X Flash Diffuser Replacement: stap 5, afbeelding 1 van 1
    • Next, the back cover.
    • Apply pressure to remove the back plate.
    • Be careful of the buttons on the top of the camera falling off, they are small parts and CAN get lost easily.
    • The best way to remove the back is to stick your thumbs on either side of the battery socket and separate from there.
  6. Leica Z2X Flash Diffuser Replacement: stap 6, afbeelding 1 van 1
    • You should now have removed the front and back plates.
  7. Leica Z2X Flash Diffuser Replacement: stap 7, afbeelding 1 van 1
    • Removing the flash diffuser should be simple from here.
    • Simply take the front cover and apply pressure to the front of the flash diffuser and it should pop right out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kenny
57 Reputatie
3 handleidingen geschreven
Cal Poly, Team 18-19, Garner Spring 2011 Lid van Cal Poly, Team 18-19, Garner Spring 2011
CPSU-GARNER-S11S18G19
4 Leden
13 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 18
Altijd: 3,210
