Inleiding
This guide was created to assist users in replacing the buttons on their left Nintendo Switch Joy-con. Please note that this guide does not contain steps for the right Joy-Con. The process for the right Joy-con is different and a bit more difficult. The process for replacing the buttons in the left Joy-Con consists of opening the Joy-Con, removing each of the inner pieces, batteries, and motherboard, then locating, removing, and replacing the desired buttons.
Wat je nodig hebt
Remove the four screws located on the back casing with a Y00 screwdriver.
Insert a plastic opening tool or pick into the side of the Joy-Con without the rail and gently pry downwards to release the back plate.
To reassemble your device, follow these instructions in reverse order. Make sure when you are screwing the motherboard back into place you do not screw it in too tightly. If the motherboard is too tight to the buttons it could keep the buttons from pushing properly.
30 andere personen hebben deze handleiding voltooid.
8 opmerkingen
My left directional button is nonresponsive. Can I fix this by dropping in a replacement left directional button? Would the rubber cover need to be replaced as well?
just incase you havent done so already, it might not be the button. it might be the motherboard, connectors, and a whole slew of other problems.
What type of switch is the minus button? It’s on the same ribbon as the L micro switch. My L switch is bad and I’m replacing it I just would like to know the name of the type of switch used on the minus button.
Thank you for the helpful guide! Is there a guide for the right Joy Con available anywhere?
Eric, no one has made a guide for the right Joy-Con yet! I’ve taken them both apart and the buttons are pretty similar. I think you can use Joshua’s button guide here and this joystick guide to guide you to the buttons in the other Joy-Con! If you do end up attempting it, consider taking some photos and making a guide for future right Joy-Con fixers. :)
