Ga door naar hoofdinhoud
Left Joy-Con Buttons Replacement
Wat je nodig hebt
  1. Left Joy-Con Buttons Replacement, Left Face Buttons: stap 1, afbeelding 1 van 2 Left Joy-Con Buttons Replacement, Left Face Buttons: stap 1, afbeelding 2 van 2
    • Remove the four screws located on the back casing with a Y00 screwdriver.
    • Insert a plastic opening tool or pick into the side of the Joy-Con without the rail and gently pry downwards to release the back plate.
  2. Left Joy-Con Buttons Replacement: stap 2, afbeelding 1 van 1
    • Open the Joy-Con toward the rail side, like a book.
    • Be careful not to damage the two fragile ribbon cables attaching the rails to the motherboard.
  3. Left Joy-Con Buttons Replacement: stap 3, afbeelding 1 van 1
    • Insert a spudger or plastic opening tool underneath the battery and gently begin prying downward to release the adhesive holding the battery in place.
    • Remove the battery from the inner casing.
    • Be careful not to pull too hard on the battery, as it is connected to the motherboard by a cord and you could risk damaging it.
  4. Left Joy-Con Buttons Replacement: stap 4, afbeelding 1 van 1
    • Gently pull the cord that's connecting the battery to the motherboard up and out of the Joy-Con.
    This step is very precise and it is easy to break the connector if done incorrectly.
    Henrik Myrhaug - Antwoord
    Yeah I broke it… it would be nice to see a more in-depth version of the video on their YouTube.
    Rosie -
    So lucky I had one to "dissect" turns out you don't pull in line with the wire it's more of a pry up/pull straight up from the board
    Michael Cicciarella - Antwoord
  5. Left Joy-Con Buttons Replacement: stap 5, afbeelding 1 van 2 Left Joy-Con Buttons Replacement: stap 5, afbeelding 2 van 2
    • Use a Phillips #2 screwdriver to remove the three screws that are locking the inner casing into place.
    There is also a phillips screw in the bottom right of the picture that needs to be removed before removing the battery holder.
    Ben Masten - Antwoord
  6. Left Joy-Con Buttons Replacement: stap 6, afbeelding 1 van 1
    • Open up the inner casing in the opposite direction you opened up the outer casing.
    • Be careful not to damage the one fragile ribbon cable attaching the inner casing to the motherboard.
    It should be noted the parts of the inner casing that are closest to the rail have adhesive on them that may need a little coaxing (seen in white on the right side of the above image)
    Sami Ring - Antwoord
  7. Left Joy-Con Buttons Replacement: stap 7, afbeelding 1 van 1
    • Using tweezers, gently lift up on the black or grey clasps holding down each of the 5 ribbon cables connected to the motherboard.
    • Using the tweezers, gently pull each of the ribbon cables out from their connections.
    I use these tutorials to also learn what each part is so I wish these were labeled with their proper names
    Dimarnae Deveau - Antwoord
  8. Left Joy-Con Buttons Replacement: stap 8, afbeelding 1 van 1
    • Using a Phillips #2 screwdriver, unscrew both screws connecting the analog stick to the motherboard.
    Don’t forget to take off the blue ribon at the right side of the right screw
    max_maxi - Antwoord
    This step and the next are not really necessary unless you are replacing the analog stick.
  9. Left Joy-Con Buttons Replacement: stap 9, afbeelding 1 van 1
    • Carefully lift the analog stick up and out from the Joy-Con.
  10. Left Joy-Con Buttons Replacement: stap 10, afbeelding 1 van 1
    • Using a Phillips #2 screwdriver, remove the two screws holding the motherboard in place.
  11. Left Joy-Con Buttons Replacement: stap 11, afbeelding 1 van 2 Left Joy-Con Buttons Replacement: stap 11, afbeelding 2 van 2
    • Carefully remove the rumble pack connected to the motherboard by gently lifting it out of its casing.
    • You may need to lift with a little force, as this piece is connected with adhesive.
    • Do not disconnect the cord connecting the rumble pack to the motherboard.
    • Carefully lift both the rumble pack and motherboard out of the outer casing.
  12. Left Joy-Con Buttons Replacement: stap 12, afbeelding 1 van 1
    • Using a Phillips #2 screwdriver, remove the three screws holding the minus button and L button into place.
  13. Left Joy-Con Buttons Replacement: stap 13, afbeelding 1 van 1
    • Locate and remove all of the rubber casings covering the buttons.
  14. Left Joy-Con Buttons Replacement: stap 14, afbeelding 1 van 1
    • Use tweezers to remove all the buttons that you would like to replace.
    • Be careful not to turn the Joy-Con over as the buttons are now loose and could fall out.
  15. Left Joy-Con Buttons Replacement: stap 15, afbeelding 1 van 1
    • Using tweezers, carefully place all your new buttons into the Joy-Con.
    • Make sure each of the notches on the buttons are properly lined up to the notches in the Joy-Con. Failure to do so could lead to non-responsive buttons.
Conclusie
To reassemble your device, follow these instructions in reverse order. Make sure when you are screwing the motherboard back into place you do not screw it in too tightly. If the motherboard is too tight to the buttons it could keep the buttons from pushing properly.
30 andere personen hebben deze handleiding voltooid.
8 opmerkingen
My left directional button is nonresponsive. Can I fix this by dropping in a replacement left directional button? Would the rubber cover need to be replaced as well?
Blade Dub - Antwoord
just incase you havent done so already, it might not be the button. it might be the motherboard, connectors, and a whole slew of other problems.
john gerardo -
What type of switch is the minus button? It’s on the same ribbon as the L micro switch. My L switch is bad and I’m replacing it I just would like to know the name of the type of switch used on the minus button.
brantleycmd - Antwoord
Thank you for the helpful guide! Is there a guide for the right Joy Con available anywhere?
ericsajedi - Antwoord
Eric, no one has made a guide for the right Joy-Con yet! I’ve taken them both apart and the buttons are pretty similar. I think you can use Joshua’s button guide here and this joystick guide to guide you to the buttons in the other Joy-Con! If you do end up attempting it, consider taking some photos and making a guide for future right Joy-Con fixers. :)
Taylor Dixon -
Thanks for sharing this awesome guide! The first Joy-Con repair went great but i just tried repairing a second Joy-Con and after calibrating it’s drifting really bad. The replacement joystick I used was from Amazon and only $6 so I’m assuming that’s why it didn’t work. I just ordered a new replacement joystick from iFixit so hopefully that one is better quality and works. Thanks again!
my L button wasn't working and i bought a replacement piece along with the screwdrivers. this guide helped me a lot!
MeMoTie - Antwoord
Mon bouton left ne fonctionné plus , problème résolu grâce à ce tuto ,trop simple en faite .
Jean-Paul Verhaeghem - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 39
Afgelopen 7 dagen: 280
Afgelopen 30 dagen: 1,450
Altijd: 67,605
