Ga door naar hoofdinhoud
Leapfrog My Own Leaptop Speaker Replacement Guide
Wat je nodig hebt
  1. Leapfrog My Own Leaptop Speaker Replacement Guide, Battery: stap 1, afbeelding 1 van 1
    • Flip over device so that back portion of the device is facing you.
  2. Leapfrog My Own Leaptop Speaker Replacement Guide: stap 2, afbeelding 1 van 1
    • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
    • Please note that the screw cannot be removed as it is attached to the battery cover.
  3. Leapfrog My Own Leaptop Speaker Replacement Guide: stap 3, afbeelding 1 van 2 Leapfrog My Own Leaptop Speaker Replacement Guide: stap 3, afbeelding 2 van 2
    • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
    • Remove the three AA batteries.
    • Note the direction of the batteries for when reassembling.
  4. Leapfrog My Own Leaptop Speaker Replacement Guide, Speaker: stap 4, afbeelding 1 van 1
    • Remove the eleven 10mm screws from the back of the device with a a PH1 phillips head screwdriver.
  5. Leapfrog My Own Leaptop Speaker Replacement Guide: stap 5, afbeelding 1 van 1
    • Carefully remove back of the device.
    • Make sure not to rip the wires when lifting the cover off.
  6. Leapfrog My Own Leaptop Speaker Replacement Guide: stap 6, afbeelding 1 van 2 Leapfrog My Own Leaptop Speaker Replacement Guide: stap 6, afbeelding 2 van 2
    • Unscrew the two 7.5 mm screws to the left and right of the speaker with a PH1 phillips head screwdriver.
    • Remove the cover and place to the side.
  7. Leapfrog My Own Leaptop Speaker Replacement Guide: stap 7, afbeelding 1 van 2 Leapfrog My Own Leaptop Speaker Replacement Guide: stap 7, afbeelding 2 van 2
    • Once the cover is removed, gently lift up the speaker making sure not to rip or break the wires.
    • If you are disassembling the device to clean the speaker, clean it at this point with a soft, lightly dampened cloth.
    • Gently turn the speaker over and carefully desolder the white and yellow wires from the speaker.
Conclusie
Any issues that cannot be resolved with any portion of this wiki please contact Leapfrog Customer Serivce
3 andere personen hebben deze handleiding voltooid.
Jonathan Fitzer
584 Reputatie
3 handleidingen geschreven
USF Tampa, Team 14-6, Lacy Spring 2016 Lid van USF Tampa, Team 14-6, Lacy Spring 2016
USFT-LACY-S16S14G6
4 Leden
6 handleidingen geschreven
5 opmerkingen
Thanks for this very useful instruction. Where can I buy a replacement speaker?
-Don
Don La - Antwoord
I agree, but I also second the question...where can I buy a replacement speaker?
Jimmy Liang - Antwoord
Where could I purchase a replacement speaker?
Zuzi - Antwoord
Where could I buy the replacement speaker in Malaysia?
stanley.met - Antwoord
Where can I buy replacement speaker in Malaysia? Appreciate yr reply
ribenabona - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 41
Altijd: 6,736
