Ga door naar hoofdinhoud
Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide
Wat je nodig hebt
  1. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide, Battery: stap 1, afbeelding 1 van 1
    • Flip over device so that back portion of the device is facing you.
  2. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: stap 2, afbeelding 1 van 1
    • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
    • Please note that the screw cannot be removed as it is attached to the battery cover.
  3. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: stap 3, afbeelding 1 van 2 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: stap 3, afbeelding 2 van 2
    • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
    • Remove the three AA batteries.
    • Note the direction of the batteries for when reassembling.
  4. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide, Keyboard Buttons: stap 4, afbeelding 1 van 1
    • Remove the eleven 10mm screws from the back of the device with a a PH1 phillips head screwdriver.
  5. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: stap 5, afbeelding 1 van 1
    • Carefully remove back of the device.
    • Make sure not to rip the wires when lifting the cover off.
  6. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: stap 6, afbeelding 1 van 2 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: stap 6, afbeelding 2 van 2
    • Remove the three 10mm screws from the upper left hand corner white plastic piece with a PH1 phillips head screwdriver.
    • Unscrew the five 4mm screws from the plastic membrane with a PH1 phillips head screwdriver.
  7. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: stap 7, afbeelding 1 van 1
    • Remove the white plastic piece and place it to the side.
  8. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: stap 8, afbeelding 1 van 3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: stap 8, afbeelding 2 van 3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: stap 8, afbeelding 3 van 3
    • Gently grab the membrane and peal it upwards.
    • Carefully remove the membrane and set it to the side.
    • From this step you can also clean the membrane of any residue with a lightly dampened paper towel.
    • Ensure that the membrane is completely dry before reassembly.
  9. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: stap 9, afbeelding 1 van 2 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: stap 9, afbeelding 2 van 2
    • Gently lift and remove the foam piece
  10. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: stap 10, afbeelding 1 van 3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: stap 10, afbeelding 2 van 3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: stap 10, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • From here, each button is able to be removed for cleaning or replacement.
    • Using a tweezers or needle nose pliers, remove the necessary pieces from the device.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Jonathan Fitzer
629 Reputatie
3 handleidingen geschreven
USF Tampa, Team 14-6, Lacy Spring 2016 Lid van USF Tampa, Team 14-6, Lacy Spring 2016
USFT-LACY-S16S14G6
4 Leden
6 handleidingen geschreven
6Gids Commentaar
Very useful. but where to get a new membrane? please help
Alina Timchenko - Antwoord
Didn't work. I'll buy a new toy.
victoria_nglover19 - Antwoord
Is the screen on this suppose to light up?
stewartmelinda41 - Antwoord
I was wondering if the screen is suppose to light up because the one I have doesnt
thank you very much
Njabulo Mbele - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 68
Altijd: 5,908
