Inleiding
During this guide you will take apart the leapfrog and replace the board containing the speaker, audio jack, and directional pad.
Wat je nodig hebt
Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
Disconnect the audio cord from the motherboard using a plastic opening tool.
