Inleiding
If your display assembly is scratched or not working properly this is the appropriate guide to get the issue resolved. It is a rather lengthy, however, it is complete and few tools are needed.
Wat je nodig hebt
Video overzicht
Gereedschap gebruikt in deze stap:Anti-Static Wrist Strap$7.95
Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
Disconnect the audio cord from the motherboard using a plastic opening tool.
Unplug the front facing camera cord with an opening tool to free the top of the motherboard.
Unscrew the eight 6.5mm Phillips #0 screws from the plastic casing.
5 andere personen hebben deze handleiding voltooid.
4 opmerkingen
Bonjour, j’ai bien réussi à accéder à l’écran,
Ma question:
Oû peut-on se procurer un écran neuf SVP?
