Ga door naar hoofdinhoud
LeapFrog Scribble and Write Motherboard Replacement
Wat je nodig hebt
  1. LeapFrog Scribble and Write Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Use a Phillips head screwdriver to remove the screw from the battery compartment on the back of the toy.
  2. LeapFrog Scribble and Write Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the back battery cover and all of the batteries.
  3. LeapFrog Scribble and Write Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the nine case screws from the back of the toy.
    • Be careful to keep track of the screws.
  4. LeapFrog Scribble and Write Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the back cover from your toy.
  5. LeapFrog Scribble and Write Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Using a Phillips screwdriver, remove the four screws from the motherboard.
  6. LeapFrog Scribble and Write Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the keyboard ribbon from the motherboard.
  7. LeapFrog Scribble and Write Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the speaker wires from the motherboard with your soldering iron.
  8. LeapFrog Scribble and Write Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the battery wires from the motherboard with the soldering iron.
  9. LeapFrog Scribble and Write Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the switch wires from the motherboard with the soldering iron.
  10. LeapFrog Scribble and Write Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Remove the pen wires from the motherboard with the soldering iron.
  11. LeapFrog Scribble and Write Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Remove the volume control switch from the motherboard with the soldering iron.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Shang
328 Reputatie
3 handleidingen geschreven
USF Tampa, Team 1-5, Nance Spring 2016 Lid van USF Tampa, Team 1-5, Nance Spring 2016
USFT-NANCE-S16S1G5
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 17
Altijd: 680
