Ga door naar hoofdinhoud
LeapFrog Scribble and Write Eraser Slider Cleaning
Wat je nodig hebt
  1. LeapFrog Scribble and Write Eraser Slider Cleaning, Eraser Slider: stap 1, afbeelding 1 van 1
    • Turn the toy over so the back is facing upward.
  2. LeapFrog Scribble and Write Eraser Slider Cleaning: stap 2, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, carefully remove all 9 screws.
    • Set aside screws in a safe place for later reassembly.
  3. LeapFrog Scribble and Write Eraser Slider Cleaning: stap 3, afbeelding 1 van 1
    • Remove the back of the toy by carefully lifting it up.
  4. LeapFrog Scribble and Write Eraser Slider Cleaning: stap 4, afbeelding 1 van 2 LeapFrog Scribble and Write Eraser Slider Cleaning: stap 4, afbeelding 2 van 2
    • Using a Phillips #0 screwdriver, remove the two screws that secure the screen to the motherboard.
    • Set aside screws in a safe place.
    • Gently remove the motherboard to expose the display screen and eraser slider.
  5. LeapFrog Scribble and Write Eraser Slider Cleaning: stap 5, afbeelding 1 van 1
    • Carefully remove the display screen, leaving the eraser slider attached.
  6. LeapFrog Scribble and Write Eraser Slider Cleaning: stap 6, afbeelding 1 van 2 LeapFrog Scribble and Write Eraser Slider Cleaning: stap 6, afbeelding 2 van 2
    • Use the Phillips #0 screwdriver to remove the eraser slider.
  7. LeapFrog Scribble and Write Eraser Slider Cleaning: stap 7, afbeelding 1 van 1
    • Lastly, use a soft towel to clean the eraser slider, removing any debris.
    • When all previous seven steps are completed, go backwards and re-screw and put together your The LeapFrog Scribble and Write
Conclusie
Shang
328 Reputatie
3 handleidingen geschreven
USF Tampa, Team 1-5, Nance Spring 2016 Lid van USF Tampa, Team 1-5, Nance Spring 2016
USFT-NANCE-S16S1G5
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 685
