Ga door naar hoofdinhoud
LeapFrog Scribble and Write Display Screen Replacement
Wat je nodig hebt
  1. LeapFrog Scribble and Write Display Screen Replacement, Display Screen: stap 1, afbeelding 1 van 2 LeapFrog Scribble and Write Display Screen Replacement, Display Screen: stap 1, afbeelding 2 van 2
    • Turn your toy over.
    • Use a Phillips screwdriver to remove the nine case screws from the back of the toy.
    • Be careful to keep track of the screws.
  2. LeapFrog Scribble and Write Display Screen Replacement: stap 2, afbeelding 1 van 1
    • Carefully remove the back of the toy..
  3. LeapFrog Scribble and Write Display Screen Replacement: stap 3, afbeelding 1 van 2 LeapFrog Scribble and Write Display Screen Replacement: stap 3, afbeelding 2 van 2
    • Use a Philips screwdriver to remove the two screws attached to the motherboard.
    • Remove the motherboard.
  4. LeapFrog Scribble and Write Display Screen Replacement: stap 4, afbeelding 1 van 2 LeapFrog Scribble and Write Display Screen Replacement: stap 4, afbeelding 2 van 2
    • Remove the screen.
    • Remove the two pins from the bottom of the screen.
  5. LeapFrog Scribble and Write Display Screen Replacement: stap 5, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the screw from the green clip that holds the two screen layers together.
  6. LeapFrog Scribble and Write Display Screen Replacement: stap 6, afbeelding 1 van 2 LeapFrog Scribble and Write Display Screen Replacement: stap 6, afbeelding 2 van 2
    • Separate the blue and the white films.
    • Clean both films with paper towel.
    • Make sure there are no dirty spots before putting the films back together.
Conclusie
Shang
328 Reputatie
3 handleidingen geschreven
USF Tampa, Team 1-5, Nance Spring 2016 Lid van USF Tampa, Team 1-5, Nance Spring 2016
USFT-NANCE-S16S1G5
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 33
Altijd: 4,806
