Ga door naar hoofdinhoud
LeapFrog LeapTV Controller Button Replacement
Wat je nodig hebt
  1. LeapFrog LeapTV Controller Button Replacement, Battery: stap 1, afbeelding 1 van 1
    • Use the Metal Spudger to push the release clip on the battery cover.
  2. LeapFrog LeapTV Controller Button Replacement: stap 2, afbeelding 1 van 1
    • Lift the cover off.
  3. LeapFrog LeapTV Controller Button Replacement: stap 3, afbeelding 1 van 1
    • The battery holder is now visible with the removal of the cover.
  4. LeapFrog LeapTV Controller Button Replacement, Buttons: stap 4, afbeelding 1 van 1
    • Use the screwdriver to remove the eight 8.7mm PH1 Phillips head screws.
  5. LeapFrog LeapTV Controller Button Replacement: stap 5, afbeelding 1 van 1
    • Slightly lift up on the back cover until the handle covers are free to rotate.
  6. LeapFrog LeapTV Controller Button Replacement: stap 6, afbeelding 1 van 1
    • Slide the the side of the handle facing you to the left to reveal the "A" and "B" button circuit board.
  7. LeapFrog LeapTV Controller Button Replacement: stap 7, afbeelding 1 van 1
    • Use the screwdriver to remove the three 8.5mm PH1 Phillips head screws.
  8. LeapFrog LeapTV Controller Button Replacement: stap 8, afbeelding 1 van 1
    • Lift up on the circuit board and move it to the side.
    • Be careful to not cause excess stress to the connecting wires when handling the circuit board. Excess stress can cause solder points to break.
  9. LeapFrog LeapTV Controller Button Replacement: stap 9, afbeelding 1 van 1
    • Use the plastic opening tool to release the buttons from the controller casing.
  10. LeapFrog LeapTV Controller Button Replacement: stap 10, afbeelding 1 van 1
    • Remove the "A" and "B" buttons by pulling up on one of the buttons.
  11. LeapFrog LeapTV Controller Button Replacement: stap 11, afbeelding 1 van 1
    • Buttons are now removed.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Triston Fischer
128 Reputatie
1 Handleiding geschreven
IUPUI, Team S4-G2, Baechle Spring 2017 Lid van IUPUI, Team S4-G2, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G2
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 387
