Ga door naar hoofdinhoud
LeapFrog LeapPad2 Explorer Back Cover Replacement
Wat je nodig hebt
  1. LeapFrog LeapPad2 Explorer Back Cover Replacement, Battery: stap 1, afbeelding 1 van 2 LeapFrog LeapPad2 Explorer Back Cover Replacement, Battery: stap 1, afbeelding 2 van 2
    • Before disassembling your LeapPad, ensure your device is shut off.
    • Push outward on the plastic side panels to remove and reveal battery.
    • The panels should detach fully from the main device.
  2. LeapFrog LeapPad2 Explorer Back Cover Replacement: stap 2, afbeelding 1 van 3 LeapFrog LeapPad2 Explorer Back Cover Replacement: stap 2, afbeelding 2 van 3 LeapFrog LeapPad2 Explorer Back Cover Replacement: stap 2, afbeelding 3 van 3
    • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
    • Remove all four AA alkaline batteries from the device.
  3. LeapFrog LeapPad2 Explorer Back Cover Replacement, Back Cover: stap 3, afbeelding 1 van 2 LeapFrog LeapPad2 Explorer Back Cover Replacement, Back Cover: stap 3, afbeelding 2 van 2
    • This step will void your device warranty.
    • Remove the following screws securing the back cover to the main device:
    • Two 10.0 mm Phillips screws
    • Four 4.0 mm Phillips screws
    • Three 3.0 mm Phillips screws
  4. LeapFrog LeapPad2 Explorer Back Cover Replacement: stap 4, afbeelding 1 van 3 LeapFrog LeapPad2 Explorer Back Cover Replacement: stap 4, afbeelding 2 van 3 LeapFrog LeapPad2 Explorer Back Cover Replacement: stap 4, afbeelding 3 van 3
    • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
    • Move the plastic opening tool around the perimeter of the LeapPad2.
    • Lift up and remove the rear case from the tablet.
    • A butter knife can help when prying the device.
Conclusie
Nupur Garg
867 Reputatie
7 handleidingen geschreven
Cal Poly, Team 8-10, Regan Spring 2014 Lid van Cal Poly, Team 8-10, Regan Spring 2014
CPSU-REGAN-S14S8G10
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 1,437
