Inleiding
This guide provides steps for replacing the home button in the LeapFrog LeapPad Ultra XDi (model number 33300).
The home button allows you to return to the home screen from apps and other pages on the device. When this part is not working properly you will not be able to return to the home screen using this button or may experience delays. You should first try the home button troubleshooting guide before replacing the entire home button. A new home button is also required for this guide.
Before beginning, make sure to power down the device completely and disconnect it from any power source.
Wat je nodig hebt
Orient the tablet so it’s laying screen down and the barcode sticker is facing up.
Remove the barcode sticker to expose the two screws.
Locate the three ribbon cables on top of the motherboard.
Flip up the locking clip on the ribbon cable connector to release the cable.
Disconnect the cables from their connectors.
