Inleiding
Conducting a speaker replacement for the LeapPad Ultimate is a moderate task. It requires a pair of curved tweezers and a Phillips head screwdriver.
Wat je nodig hebt
Flip over the Pad to its back side to begin the removal of the back panel.
Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
Remove the back panel of the device exposing the internal components of the device.
Once the internal components are exposed locate the point which connects the battery to the motherboard.
The point connecting the battery and motherboard is made up of three wires, red, white, and black.
The plastic portion on the motherboard's end will have a small notch on top. Pull the notch in the direction towards the battery with the curved tweezers. This will disconnect the wires from the motherboard.
Één opmerking
the battery is very difficult to remove, there is too much adhesive tape on the back. I had to do an internal cleaning because my son put some fruit juice inside and because of that there was no sound coming from the LeapPad, after a deep cleaning with alcohol it worked fine again.
