Ga door naar hoofdinhoud
LeapFrog LeapPad Ultimate LCD Screen Replacement
Wat je nodig hebt
  1. LeapFrog LeapPad Ultimate LCD Screen Replacement, Back Panel: stap 1, afbeelding 1 van 2 LeapFrog LeapPad Ultimate LCD Screen Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Flip over the Pad to its back side to begin the removal of the back panel.
    • Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
    • This is very difficult to remove , so do be patient. To help remove the seal, both a metal spudger and plastic opening tool may be used.
    • Remove the pen from its place before starting to avoid tangling.
  2. LeapFrog LeapPad Ultimate LCD Screen Replacement: stap 2, afbeelding 1 van 2 LeapFrog LeapPad Ultimate LCD Screen Replacement: stap 2, afbeelding 2 van 2
    • Once the blue rim is removed, the 12 screws will be visible.
    • Use the Phillips #1 screwdriver to unscrew all 12 screws.
  3. LeapFrog LeapPad Ultimate LCD Screen Replacement, LCD Screen: stap 3, afbeelding 1 van 3 LeapFrog LeapPad Ultimate LCD Screen Replacement, LCD Screen: stap 3, afbeelding 2 van 3 LeapFrog LeapPad Ultimate LCD Screen Replacement, LCD Screen: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • The segment connecting the battery to the motherboard will consist of red, white, and black wires.
    • There is a small notch on the segment. Use the curved tweezers to pull the notch in the direction of the battery. this will disconnect the battery from the motherboard.
    • The battery is the bright orange rectangle.
    • The motherboard is the large dark green surface.
  4. LeapFrog LeapPad Ultimate LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Carefully remove the battery from its place and set aside.
    • Removing the battery will fully expose a white and blue ribbon cable that runs beneath the battery.
    • The ribbon cable must be disconnected from the motherboard and removed from the panel.
  5. LeapFrog LeapPad Ultimate LCD Screen Replacement: stap 5, afbeelding 1 van 2 LeapFrog LeapPad Ultimate LCD Screen Replacement: stap 5, afbeelding 2 van 2
    • The ZIF connector which connects the ribbon cable and the motherboard has a small flap on the top.
    • Use the curved tweezers to to flip the flap up.
    • Once it is disconnected, carefully pull the ribbon cable through the 2 black plastic arches holding it down.
  6. LeapFrog LeapPad Ultimate LCD Screen Replacement: stap 6, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to unscrew the 7 screws on the speaker.
    • 5 will be on the brown part and 2 on the circular blur part.
    • Once it is unscrewed completely, remove the speaker and set aside.
  7. LeapFrog LeapPad Ultimate LCD Screen Replacement: stap 7, afbeelding 1 van 1
    • An orange and black ribbon cable connects the motherboard and the area to the side of the panel.
    • There is a switch on top of it.
    • Use the curved tweezers to flip the switch.
  8. LeapFrog LeapPad Ultimate LCD Screen Replacement: stap 8, afbeelding 1 van 1
    • Unscrew the 3 screws on the motherboard with a Phillips #1 screwdriver.
  9. LeapFrog LeapPad Ultimate LCD Screen Replacement: stap 9, afbeelding 1 van 2 LeapFrog LeapPad Ultimate LCD Screen Replacement: stap 9, afbeelding 2 van 2
    • Flip the motherboard over to expose the uderside.
    • There is a wide black ribbon with a swtich. Flip the switch and set aside the motherboard.
  10. LeapFrog LeapPad Ultimate LCD Screen Replacement: stap 10, afbeelding 1 van 2 LeapFrog LeapPad Ultimate LCD Screen Replacement: stap 10, afbeelding 2 van 2
    • Along the side of the blue panel are 6 screws. Unscrew each of the screws with a Phillips #1 screwdriver.
    • Remove the panel and the remainder of its contents and set aside.
  11. LeapFrog LeapPad Ultimate LCD Screen Replacement: stap 11, afbeelding 1 van 1
    • The screen is now exposed and can be removed and replaced.
Conclusie
Één opmerking
Where did you find a Replacement screen? Are there any identifying part numbers?
Johan Rodriguez - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 27
Altijd: 4,682
