Ga door naar hoofdinhoud
LeapFrog LeapPad Ultimate Camera Replacement
Wat je nodig hebt
  1. LeapFrog LeapPad Ultimate Camera Replacement, Back Panel: stap 1, afbeelding 1 van 2 LeapFrog LeapPad Ultimate Camera Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Flip over the Pad to its back side to begin the removal of the back panel.
    • Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
    • This is very difficult to remove , so do be patient. To help remove the seal, both a metal spudger and plastic opening tool may be used.
    • Remove the pen from its place before starting to avoid tangling.
  2. LeapFrog LeapPad Ultimate Camera Replacement: stap 2, afbeelding 1 van 2 LeapFrog LeapPad Ultimate Camera Replacement: stap 2, afbeelding 2 van 2
    • Once the blue rim is removed, the 12 screws will be visible.
    • Use the Phillips #1 screwdriver to unscrew all 12 screws.
  3. LeapFrog LeapPad Ultimate Camera Replacement, Camera: stap 3, afbeelding 1 van 1
    • Remove the 3 screws on each corner of the motherboard
  4. LeapFrog LeapPad Ultimate Camera Replacement: stap 4, afbeelding 1 van 3 LeapFrog LeapPad Ultimate Camera Replacement: stap 4, afbeelding 2 van 3 LeapFrog LeapPad Ultimate Camera Replacement: stap 4, afbeelding 3 van 3
    • Remove the ribbon on the bottom of the motherboard and the ribbon on the left side of the motherboard.
    • There will be a small black switch on top of the ribbons that you must flip to take them out.
  5. LeapFrog LeapPad Ultimate Camera Replacement: stap 5, afbeelding 1 van 1
    • Remove the 3-pin connector on the top left side of the motherboard.
  6. LeapFrog LeapPad Ultimate Camera Replacement: stap 6, afbeelding 1 van 2 LeapFrog LeapPad Ultimate Camera Replacement: stap 6, afbeelding 2 van 2
    • Flip the motherboard to its back side and pinch the 2 green hooks to remove the camera cover
  7. LeapFrog LeapPad Ultimate Camera Replacement: stap 7, afbeelding 1 van 1
    • Remove the ribbon connecting the camera to the motherboard. You have now taken out the camera and can replace it with a new one.
Conclusie
Nabil Mustafa
223 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 207
