Ga door naar hoofdinhoud
LeapFrog LeapPad Ultimate Back Panel Replacement
Wat je nodig hebt
  1. LeapFrog LeapPad Ultimate Back Panel Replacement, Back Panel: stap 1, afbeelding 1 van 2 LeapFrog LeapPad Ultimate Back Panel Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Flip over the Pad to its back side to begin the removal of the back panel.
    • Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
    • This is very difficult to remove , so do be patient. To help remove the seal, both a metal spudger and plastic opening tool may be used.
    • Remove the pen from its place before starting to avoid tangling.
  2. LeapFrog LeapPad Ultimate Back Panel Replacement: stap 2, afbeelding 1 van 2 LeapFrog LeapPad Ultimate Back Panel Replacement: stap 2, afbeelding 2 van 2
    • Once the blue rim is removed, the 12 screws will be visible.
    • Use the Phillips #1 screwdriver to unscrew all 12 screws.
Conclusie
Nabil Mustafa
223 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 1,190
