Wat je nodig hebt
Turn the tablet so the back is facing up.
Remove the battery covers by sliding the covers towards the sides and away from the center of the device.
Remove three 7 mm screws using a Phillips #1 screwdriver.
Remove the single 6 mm screw using a Phillips #1 screwdriver.
Remove the single 10 mm screw using a Phillips #1 screwdriver.
Use a small plastic opening tool to separate the colored front cover from the white rear cover of the device.
With one hand on the front cover and one hand on the rear cover, start from the bottom of the device and pull the pieces apart.
Once only the top edge remains connected, pull the rear cover backwards away from the front cover and upwards towards the top of the device. This should release the last remaining tabs holding the pieces front and rear cover together.
