Ga door naar hoofdinhoud
N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide
Wat je nodig hebt
  1. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide, Leaf Spring Switch: stap 1, afbeelding 1 van 1
    • Place the blaster upside down on the table, and remove the screw in the bottom of the handle.
    • Remove the battery door and take the batteries out.
  2. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: stap 2, afbeelding 1 van 3 N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: stap 2, afbeelding 2 van 3 N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: stap 2, afbeelding 3 van 3
    • Set the blaster on its side with the screws facing up (the blaster will be placed on its left side). Remove all 14 phillips head, 8.2 mm screws and set them aside.
    • Lift the side of the blaster off exposing its internal parts.
  3. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: stap 3, afbeelding 1 van 1
    • Work the trigger to ensure the problem is the switch not making a proper connection.
    • Remove the retaining phillips head 10.2 mm screw below the switch.
  4. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: stap 4, afbeelding 1 van 1
    • Use a hot soldering iron to melt the solder of the two wires at the rear of the switch. Take note that the red wire leads from the top of the switch.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jeffrey Sargeant
354 Reputatie
1 Handleiding geschreven
Michigan Tech, Team 5-8, Lauer Spring 2014 Lid van Michigan Tech, Team 5-8, Lauer Spring 2014
MTU-LAUER-S14S5G8
3 Leden
13 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 1,947
