Ga door naar hoofdinhoud
Leader Impression i10A-LE Speakers Replacement
Wat je nodig hebt
  1. Leader Impression i10A-LE Speakers  Replacement, Speakers: stap 1, afbeelding 1 van 1
    • Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Speakers  Replacement: stap 2, afbeelding 1 van 3 Leader Impression i10A-LE Speakers  Replacement: stap 2, afbeelding 2 van 3 Leader Impression i10A-LE Speakers  Replacement: stap 2, afbeelding 3 van 3
    • Start by prying the back off by using plastic opening tools
    • Using the plastic tools slide the flat end into the device.
    • Gently pry the back piece until you hear a popping noise.
    • Once the back is loose, remove it from the device and set aside.
  3. Leader Impression i10A-LE Speakers  Replacement: stap 3, afbeelding 1 van 3 Leader Impression i10A-LE Speakers  Replacement: stap 3, afbeelding 2 van 3 Leader Impression i10A-LE Speakers  Replacement: stap 3, afbeelding 3 van 3
    • Use the spudger to pry both of the speakers from the tablet.
    • Follow both sets of speaker wires to the motherboard where they are connected.
    • Desolder the wire connections from the motherboard.
Conclusie
jcg
101 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 126
