Ga door naar hoofdinhoud
Leader Impression i10A-LE Front Facing Camera Replacement
Wat je nodig hebt
  1. Leader Impression i10A-LE Front Facing Camera Replacement, Front Facing Camera: stap 1, afbeelding 1 van 2 Leader Impression i10A-LE Front Facing Camera Replacement, Front Facing Camera: stap 1, afbeelding 2 van 2
    • Start by prying the back off by using plastic opening tools.
    • Slide the flat end of the plastic tools into the seam device.
    • Using another plastic tool, slowly pry along the seam until the back pops off.
  2. Leader Impression i10A-LE Front Facing Camera Replacement: stap 2, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Reminder to disconnect the battery.
    • Locate the Camera in the top left corner of the Leader Impression.
    • Using the tweezers, remove the bottom of the camera from the motherboard.
    • The top of the camera will detach as you pull upward.
  3. Leader Impression i10A-LE Front Facing Camera Replacement: stap 3, afbeelding 1 van 1
    • Remove the camera from it's slot.
Conclusie
Crystal Dorrian
231 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 118
