Inleiding
If you have confirmed the speakers are broken by also testing the volume in your settings, the speakers will need to be replaced. It is important to note that some basic knowledge regarding soldering technique and safety is required. For those who are not completely confident with their soldering skills, a guide may be accessed at Hoe moet je (de-)solderen?
Wat je nodig hebt
Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
Remove the four 3.5 mm Phillips #00 screws holding the speakers in place.
Move the speakers out of the way.
