Ga door naar hoofdinhoud
Le Pan II Charging Port Replacement
Wat je nodig hebt
  1. Le Pan II Charging Port Replacement, Screen: stap 1, afbeelding 1 van 2 Le Pan II Charging Port Replacement, Screen: stap 1, afbeelding 2 van 2
    • Insert metal spudger between front and back panel to pry apart.
    • Continue to pry while moving the metal spudger along the crevice to completely separate two panels.
    • Avoid using metal when opening devices, as it can damage or crack the screen.
  2. Le Pan II Charging Port Replacement: stap 2, afbeelding 1 van 2 Le Pan II Charging Port Replacement: stap 2, afbeelding 2 van 2
    • Use the plastic opening tool to disconnect the flat ribbon cable from the motherboard connector.
    • Disconnect the flat ribbon by gently pulling it out from its connecting port.
  3. Le Pan II Charging Port Replacement: stap 3, afbeelding 1 van 2 Le Pan II Charging Port Replacement: stap 3, afbeelding 2 van 2
    • Use the plastic opening tool to disconnect the display cable from its motherboard connector.
    • Disconnect the display cable by gently pulling it out from its connecting port.
  4. Le Pan II Charging Port Replacement: stap 4, afbeelding 1 van 1
    • Remove grey metal backing from screen.
  5. Le Pan II Charging Port Replacement: stap 5, afbeelding 1 van 1
    • Flip the tablet so the screen is facing upward, and use the metal spudger to pry apart the screen from the side pieces.
  6. Le Pan II Charging Port Replacement: stap 6, afbeelding 1 van 1
    • Lift and carefully remove the LCD display from the front cover.
  7. Le Pan II Charging Port Replacement, Charging Port: stap 7, afbeelding 1 van 1
    • Use the Phillips 00 screwdriver head to unscrew the screws to the motherboard.
    • Reminder: There should be 8 (3.5 mm) screws to the motherboard.
  8. Le Pan II Charging Port Replacement: stap 8, afbeelding 1 van 1
    • Use the Phillips 00 screwdriver head to unscrew the screws to the fan.
    • Reminder: There should be 4 (1mm) screws to the fan.
  9. Le Pan II Charging Port Replacement: stap 9, afbeelding 1 van 1
    • Use the metal spudger to pry off the charging port from the motherboard.
Conclusie
Kelly Moniz
513 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 6-3, Martin Fall 2016 Lid van UMass Dartmouth, Team 6-3, Martin Fall 2016
UMASSD-MARTIN-F16S6G3
3 Leden
10 handleidingen geschreven
Één opmerking
I have had no luck getting in touch with anyone in the customer service department.I have left several messages but have not heard from anyone yet. I just need to know how I can get a charge port for my daughters tablet. She had it 6 months before the charge port went out.
tashiarmarshall - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 1,216
