Inleiding
Use this guide to replace a fan blade in your Lasko B20540 20" 3-Speed Power Plus Box Fan.
Box fans serve as an affordable way to keep cool during warm seasons. If the fan blade is broken, the fan may not work as intended. This guide will take you through the steps to safely remove the fan blade and replace it with a new one. With a new blade installed, the fan will work properly, and be sure to help keep you cool and comfortable.
Wat je nodig hebt
Once the frame has been screwed back into place, the fan can now be plugged in and turned on.
