Inleiding
Without a functioning fuse, a Lasko CD08200 space heater will not be able to operate safely because it will have no safety mechanism to stop the current flow and prevent overpowering the device.
Please refer to this Troubleshooting guide before beginning to make sure replacing the fuse is the correct action to fix your device.
This guide will require soldering if you are not experienced in soldering. lease refer to this soldering guide.
For this replacement guide, you will need: a TR15 screwdriver, a PH2 screwdriver, and a soldering kit. A precision bit driver could also be used with the following bits:
- Torx Security 15 (TR15 bit)
- Phillips 2 (PH2 bit)
Warning: Repairing space heaters can be dangerous. Exercise extreme caution when following this guide.
Wat je nodig hebt
Turn over the device and place it on its head.
Remove the four 14mm screws holding the bottom using a TR15 screwdriver.
Remove the four 14mm screws housing the fan base using the Phillips #2 screwdriver.
Remove the fan base from the device.
Één andere persoon heeft deze handleiding voltooid.
3 opmerkingen
This is a very clearly written and beautifully photographed repair description. Thank you!
The only other information I need is a detailed description of the fuse so I can have a replacement ready to install when I begin the repair. Would you be willing to provide this information?
Thanks very much!
Salutations!
I'm afraid that neither I or my colleagues have no information on the fuse replaced on this guide. Perhaps an electrician with a careful eye may be able to help determine which fuse is required for this guide.
Best of luck on repairing your Lasko!
Thanks for your response and for your good wishes!
